T-Case Oil?
Old Jun 10, 2014 | 07:08 PM
Orange Disco's Avatar
4th Gear
Default T-Case Oil?
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
For T-Case & Diffs.
But for the tranfer case... is there one (80/90W, 85W/140 or whatever) that will help keeping it from overheating if a guy uses Low Range a lot at low speed. (below 20mph)
Since at low range, the T-Case is not getting a whole lot of air to cool down or disipate heat.
Any thoughts?
Thanx!
Old Jun 10, 2014 | 09:28 PM
blamo's Avatar
I use red line heavy shock proof it is a syn/lube
Old Jun 10, 2014 | 10:05 PM
jfall's Avatar
Amzoil makes some good oil products also..
Seems Amzoil and Redline are good.
Unless you are hauling a boat or a horse trailer, I bet your t-case at 20 MPH will be OK.
Old Jun 10, 2014 | 10:42 PM
dusty1's Avatar
lucas for me
Old Jun 11, 2014 | 12:38 AM
ls1morethanyou's Avatar
if you ned extra cooling http://www.discovery2.co.uk/tbox_cooler.html
that will help and also add more fluid to the system
Old Jun 11, 2014 | 12:49 AM
Colorado David's Avatar
Sweet. Where can you buy one of those?
Old Jun 11, 2014 | 08:44 PM
4th Gear
Ok, thanx!
Question is now... Amzoil or Redline, 80/90W or 85W/140?
Old Jun 12, 2014 | 01:37 AM
Dane!'s Avatar
That tcase sump wont fit on the V8 D2's without exhaust modifications.
kpl1228
Mar 26, 2011 06:19 PM
sailorcolin
Feb 21, 2008 05:08 PM
alex of minnesota
Dec 8, 2006 09:52 PM
Td5
Sep 1, 2006 05:01 PM
disco12
Mar 6, 2006 05:02 AM
