t-case and transmission fluid change
Old Aug 9, 2007 | 12:08 PM
jdelp's Avatar
Default t-case and transmission fluid change
How do you guys refill the fluids after changing out the t-case? Diffs are easy, but I saw someone mention using a pump for the others.
Old Aug 9, 2007 | 12:23 PM
okdiscoguy's Avatar
Default RE: t-case and transmission fluid change
go to your local parts store and get a cheap oil transfer pump. That's what I use. I used it on the front diff too, the drag link was in the way. Makes ita lot easier
Old Aug 9, 2007 | 12:25 PM
jdelp's Avatar
Cool, figured that was the deal. Thanks.
Old Aug 9, 2007 | 02:01 PM
S4poor's Avatar
This works great. $5.37 from any Marine parts store. It will come in useful for other things down the road also ;-)
http://www.iboats.com/mall/image/vendor/3/big/5503.jpg
Old Aug 9, 2007 | 02:27 PM
okdiscoguy's Avatar
I had to buy one for my lower unit. It took 3 times longer to pump 2 quarts, and a the end, the clear plastic hose popped off the nozzle and would not stay back on. Just get the red barrell pump with 2 hoses.
Old Aug 9, 2007 | 02:41 PM
S4poor's Avatar
Modify it by removing the threaded insert that screws into the outboard drive, and install a copper pipe. See pictures for modified pump.
Of course your idea is just as good ;-)
Athana
Jun 8, 2019 10:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
tshah209
May 21, 2011 08:36 PM
treant985
Dec 27, 2010 02:51 PM
grussell
Sep 2, 2009 06:46 PM
