t case wont change to low or high
Old Nov 4, 2008 | 12:06 PM
joyjimmy's Avatar
5th Gear
Default t case wont change to low or high
cant change from high to low, im trying to unlock it .
Old Nov 4, 2008 | 01:23 PM
Default RE: t case wont change to low or high
What year?????????????????????
Old Nov 4, 2008 | 05:24 PM
handsome rob's Avatar
Ditto from Disco Mike, but try to put it in neutral and let the truck move a little, it may just go right in. Do not grinfd it though.
Old Nov 4, 2008 | 05:34 PM
Jull's Avatar
Maybe the linkage is stuck.... check this page
http://home.twcny.rr.com/eeibooks/ro...codifflock.htm
Old Nov 5, 2008 | 04:16 PM
joyjimmy's Avatar
5th Gear
the linkage is ok ,I check and locks and unlocks very well. The problem changing from h to low gears.Is a disco 94
Old Nov 5, 2008 | 04:18 PM
joyjimmy's Avatar
5th Gear
disco 94. thanks
Old Nov 5, 2008 | 04:21 PM
joyjimmy's Avatar
5th Gear
I try that, even in reverse and thenneutral. thanks
Old Nov 5, 2008 | 04:25 PM
Check your tire pressure, make sure that the tires on the front are the same PSI and the back are the same PSI.
Then while moving forward at idle try and shift into low.
I have found that if your tire PSI is way off at each wheel it can "bind" up the transfer case making it hard to change gears.
Old Nov 5, 2008 | 04:28 PM
joyjimmy's Avatar
5th Gear
I check it , also lift the truck and lose all 4 tires so they can spin freely. thanks
Old Nov 6, 2008 | 09:05 AM
Jull's Avatar
Did you remove the center console to check what is going on underneath? Or was there excessive quantity of metal in the oil last time you changed the oil in your t-case? Maybe the problem comes from inside...
