t case wont change to low or high
Old Nov 6, 2008 | 09:15 AM
Default RE: t case wont change to low or high
ORIGINAL: joyjimmy
disco 94. thanks
For you 84, it is safe to sat the t/case hasn't been shifted much in a longg while and the linkage is frozen up. If you are real mechanical, you might be able to to tear it down but I would recommend a mechanic fix it.
This is a common problem, one that if you try and force it will cause more expense.
gmad
May 27, 2015 12:11 AM
omarica7
Mar 11, 2014 08:12 AM
gustav23
Dec 15, 2011 01:12 PM
collin Barrows
Aug 28, 2011 07:13 AM
Scott R
Dec 25, 2009 03:43 PM
