Tach.
Old Jan 29, 2008 | 11:10 AM
mlfore's Avatar
Default Tach.
I have a 96 disco and the tach will work some time and some time it will just jump all over the place could this be a vacuum line or any ideas to fix this? My truck is a 5 speed if that helps at all.
Old Jan 29, 2008 | 11:52 AM
Default RE: Tach.
Check for a loose wire on your alternator, which is where the tach signal comes from. If the wires are good, your tach is starting to fail, kind of a common problem with Rovers.
Old Jan 30, 2008 | 08:01 AM
mlfore's Avatar
Default RE: Tach.
I just replaced my alternator not to long ago so everything should be good. Would I have to get a whole new instrument cluster and if I do would I be able to make the miles the same as they are on my truck
Old Jan 30, 2008 | 08:55 AM
Default RE: Tach.
Well when you get more acquainted to auto parts and their reliability, you will learn that brand new out of the box doesn't mean it will work and if it does, for how long.
That being said, go to your local auto parts store and have them do a free check.
Old Jan 30, 2008 | 10:46 AM
JayhawkinIdaho's Avatar
Default RE: Tach.
With that being said,and oldbelt slipping can cause the same problem.Had this same issueon aBenz, replaced the belt, and all was fine.
Old Jan 31, 2008 | 04:02 PM
mlfore's Avatar
Default RE: Tach.
Thanks alot for the help I replaced the belt at the same time I will get the alt. checked
Old Jan 31, 2008 | 07:28 PM
Default RE: Tach.
If you wind up getting a new instrument panel you can get one from here.
http://www.roverlandparts.com/index....p;Category=264
As for making the miles the same, I used a drill attached to the speedo cable, that was on a old Oldsmobile, but it worked.
Old Jan 31, 2008 | 08:12 PM
okdiscoguy's Avatar
Default RE: Tach.
These are electronic. Your VSS reads pulses off the transfer case....
vinvelasco
Jul 13, 2008 01:07 PM
whurst79
Jun 1, 2008 07:13 PM
Inspector56
May 28, 2008 04:28 AM
racdisco
May 13, 2007 08:03 AM
Brad S1
May 8, 2007 03:21 PM
