tach issues 95 disco
Old Sep 10, 2008 | 09:31 AM
benflynn's Avatar
Default tach issues 95 disco
my tach is intermitten, i swapped it out and the new one is internitten
i know it runs off the alt, is this a common problem? if so is it usally w/the tach or the truck, never know when you have gotten a bad used part
Old Sep 10, 2008 | 09:33 AM
Default RE: tach issues 95 disco
It is ALWAYS with the alt. The tach gets its sig from the alt, when your alt goes bad your tach stops working.
Old Sep 12, 2008 | 12:10 PM
benflynn's Avatar
so, will it start showing an alt problem before other signs do
can you swapp the brushes/voltage reg?
Old Sep 12, 2008 | 01:02 PM
Yes you can rebuild the alt.
When the tach doesnt work then the alt is not charging at all and you are running off the battery alone.
JPSpen
Feb 25, 2013 05:53 PM
dansgt
Mar 17, 2012 01:22 PM
Inspector56
May 28, 2008 04:28 AM
racdisco
May 13, 2007 08:03 AM
Brad S1
May 8, 2007 03:21 PM
