Tachometer needle bouncing
Old Jan 21, 2024 | 12:53 PM
OleMissRbl's Avatar
Default Tachometer needle bouncing
My 2003 D2 with 112k miles started having this issue with the tachometer needle bouncing all over the place although the RPMs aren’t changing. You can see the live readings on my head unit. I confirmed the voltage at the alternator with a multimeter and checked the two wires on the alternator. Would the next step be to check the wire behind the tachometer to make sure it has a good connection or should I be looking for something else?
Attachment 57701
Old Jan 21, 2024 | 01:05 PM
Richard Gallant's Avatar
Could be your CPS starting to go
Old Jan 21, 2024 | 01:07 PM
OleMissRbl's Avatar
I just put in a new one (Bosch) a few weeks ago.
Old Jan 22, 2024 | 09:58 AM
disco96sd's Avatar
Possible alternator issue - even a loose wire - check connections on back of the alternator and test the alternator could be going bad
NotOverRover
LR2
Sep 28, 2023 09:44 AM
GivenyDiscoII
Dec 27, 2022 07:47 AM
94Disco1
Sep 8, 2022 06:37 PM
dipdgarage
Nov 14, 2013 11:40 PM
