Tail Light Problem
Tail Light Problem
I have a 96 D1 that has some tail light issues. The drivers side tail light does not come on. When I hit the brake it comes on, but the running light portion is off. I have tried new blubs, but that didn't fix it, I used a volt meter and did not detect any voltage on the drivers side...but did get 13.6 on the side that was working.
I don't think its ground cause the other lights in the cluster work (turn, brake, reverse)...so...
Where do I go to trace the wire and see where I am loosing voltage. What are the wires for running light on the molex connector going into the cluster?
