Tail Light Problem
Old Jan 13, 2008 | 02:59 PM
willlane's Avatar
Default Tail Light Problem
I have a 96 D1 that has some tail light issues. The drivers side tail light does not come on. When I hit the brake it comes on, but the running light portion is off. I have tried new blubs, but that didn't fix it, I used a volt meter and did not detect any voltage on the drivers side...but did get 13.6 on the side that was working.
I don't think its ground cause the other lights in the cluster work (turn, brake, reverse)...so...
Where do I go to trace the wire and see where I am loosing voltage. What are the wires for running light on the molex connector going into the cluster?
Old Jan 13, 2008 | 04:56 PM
Default RE: Tail Light Problem
Can you remove that light assembly and switch it with the other side to see if the problem persisits? It might be a bad assembly. So if you can switch them and see what happens before you go trying to chase electrical gremlins.
Old Jan 13, 2008 | 09:04 PM
okdiscoguy's Avatar
Check all of your fuses first. Make sure the dim parking light is coming on inside the headlight... They are fused side specific.
Old Jan 13, 2008 | 09:58 PM
willlane's Avatar
got it...it was a fuse. I had already fixed one but there was another too...working great now
Old Jan 13, 2008 | 10:02 PM
okdiscoguy's Avatar
Mine was like that when I got it. Easy to overlook things... Glad you got it!
rambo
Oct 17, 2013 10:13 PM
Kalel
Mar 29, 2012 08:31 PM
Unshriven
Feb 27, 2012 05:31 PM
primey
Oct 5, 2011 10:06 PM
mrmckay
Mar 28, 2007 02:15 AM
