Tailgate Hinge Pins Removable?
Old Apr 4, 2013 | 05:16 PM
CANAMDiscovery's Avatar
Default Tailgate Hinge Pins Removable?
Does the rear hinge pin come out in order to get some new "washers" in the hinge. You can see in the pic the gap and how the door has dropped that couple millimeters. I cannot get any play in the hinge by physically lifting on the door while open.
I am betting I will be needing a new lower hinge.
Old Apr 4, 2013 | 05:25 PM
Rovin4life's Avatar
you get a new hinge. have it painted before hand. and dont waste your time with a used one.
Old Apr 4, 2013 | 06:23 PM
ZGPhoto's Avatar
They always rust and need to be replaced. That's an item we sell plenty of no doubt. HINGE ASSY REAR DOOR UPPER DISCOVERY II, RNN428, BHB700032 - Land Rover Parts | Rovers North
http://landroverparts.roversnorth.co...code=BHB700051
Old Apr 5, 2013 | 10:48 AM
russburcham's Avatar
I had to get a new hinge after my tailgate swung open and bent the lower portion- You will definitely need a helper to get the door off AND you will also need to drill out a couple of rivets- Good Luck
Alex_M
Jun 25, 2015 09:46 AM
gman1001
Defender
Apr 28, 2012 11:46 AM
CoolBreeze
May 12, 2010 04:38 PM
lholho
LR2
Oct 5, 2008 02:10 PM
SuperCharged06
Defender
Aug 24, 2007 07:57 PM
