Takin my 97 Disco Off-Roadin
RE: Takin my 97 Disco Off-Roadin
Center diff lock is when you push the transfer lever to the left. It locks front and back so if (for example) back wheels are on slippery stuff, front wheels still provide traction. All-wheel-drive requires a diff for driving on the road (since the front and back will always rotate slightly differently, depending on exact tire size, turns, etc). It's okay to lock any time you're off road, but I tend to lock only when it's going to get slippery, like sand or mud.
2000-2004 Disco IIs don't have this (specifically, the diff can lock but has no lever to lock it; some can be modified).
on
ORIGINAL: discocolorado03
alright bro i have a 95 disco and i go off roading in the creek by school . no problems although i did get in a three wheel action and it wouldent go but i have stock suspension and no lockers but you should be fine just make sure if ur using the four wheel low that it is allthe way enguaged but if needed i would go with a set of two inch spacer and you can move your back coil to the front and put the pair of spacers in the back and have a two inch lift
Springs and shock and a couple of Rover riend to show him what makes his truck tick is what is needed.
Mike
Rangebmw04
06-05-2021 06:17 PM
andylad75
09-27-2009 03:39 PM
