The Tale of Two Bad Mice
Old Sep 1, 2016 | 02:40 PM
coastie's Avatar
Default The Tale of Two Bad Mice
Last month when I picked up a Disco 2 it had been sitting in a yard for two years. Upon closer examination after getting it home, I discovered a mouse had made a nest in the air box using the hood pad for nesting material. Yesterday I was took off the center console to clean it up and dound that another mouse had made a nest behind the E-brake. This one had used bits of yarn, foam, and - pink feathers. I was amused until after cleaning it out the mouse had chewed off the insulation to several wires! No breaks at least and was able to cover the wires with liquid tape. If that doesn't work I have a replacement harness on standby.
Old Sep 2, 2016 | 05:51 AM
disc oh no's Avatar
That's what you get for having such delicious wires! LOL
Old Sep 2, 2016 | 10:41 PM
XCELLER8's Avatar
I have a friend who works at a local auto dealership and he was sent to a service school....they were told that the wiring used in todays vehicles has a soy based component in the wiring insulation.....and the little bastards think is smells like food...
Old Sep 2, 2016 | 11:26 PM
MrValingo's Avatar
Something made a nest atop a 5.0 in a 16 f150 at work...had to replace every harnes in the front of the truck along with several vacuum lines and the washer fluid lines
Old Sep 3, 2016 | 08:37 AM
coastie's Avatar
Found this nest after removing the rear panel.
Old Sep 4, 2016 | 02:00 PM
T-rex's Avatar
I camped overnight in the desert west of Moab, Utah - I later found that the local mice had made a couple nests in the engine compartment using the hood pad and leaves in just that one night.
Busy little jerks.
Tony C
Jul 2, 2014 03:57 PM
04duxlr
Jan 30, 2014 10:20 AM
leftfield6
Jun 10, 2013 11:37 AM
pinkytoe69
Mar 9, 2012 11:02 AM
stan murray
Apr 23, 2010 05:16 AM
