Tapping noise after sitting 5+ hours
Old Nov 25, 2011 | 08:00 PM
Discolife's Avatar
Open your copy of the RAVE, workshop manual, emissions controls. It has an electric pump, some solenoid and vac operated valves, and is a known source of "the tick" (but not the only source). Also, if you have a 97, it is not a D2, so it won't have one and you may not find what you seek in this part of the forum. More likely you have oil pressure / oil pump problem, or flex plate cracked (tranny to flywheel interface).
brans spanking new TC cover and oil pump.
Funny thing I just went outside sto start it and it was quiet as a mouse
Old Nov 25, 2011 | 08:16 PM
Originally Posted by Discolife
where is the sai system and what does it do?
The Secondary Air Injection system is only on DII's, it is on the passenger side of the engine.
It is a emissions device that injects fresh air into the raw exhaust of a cold engine to aid in the heating up of the catalytic converters to reduce emissions.
Cats only work when hot, the faster they heat up the less pollution.
Old Nov 25, 2011 | 08:37 PM
lordmorpheus's Avatar
...and FTR, I don't have SAI. Ever since last January or so, it has been almost quiet as a mouse, less what I believe to be a small exhaust leak causing a faint tick, which I haven't looked into yet.
texasdisco1
Jul 21, 2013 05:41 PM
adigerol77
Mar 23, 2012 05:17 PM
Jetswede
Mar 21, 2011 09:08 AM
Murph_Dog
Feb 15, 2010 10:57 PM
walteroscar
Sep 8, 2006 03:17 PM
