TC light flashed?
Old 08-21-2015, 08:08 AM
MPDano's Avatar
Originally Posted by Charlie_V
I thinks that's normal.
Wheww. Good to know, just trying to be proactive. Thanks guys for all the great info!
Old 08-21-2015, 08:15 AM
Charlie_V's Avatar
Mine does that sometimes. You may hear a sound and feel a brake pedal shudder... that's just the ABS making sure you don't get stuck and can drive straight. Basically, it gives some ABS love to your diff. You're in good shape.
Old 08-21-2015, 11:53 AM
As an aside, I took the D2 out today for a run and whilst on the local gravelly road I spun up the wheels on a slow right hand bend, the TC kicked in (which you can hear as it sounds exactly like ABS working/juddering) and the TC light flashed on. The other easier way is on gravel from a standing start with half or full turning lock and then accelerate hard and the TC kicks in immediately and the TC warning light shows.
Old 08-25-2015, 10:54 AM
MPDano's Avatar
Well, got the 3 Amigos. I took a pic this way it's documented on what it actually looks like. After extensive search, I couldn't find anything to show what lights are the 3 on. Anyways, found this video very useful on what to check and replace. At least the ABS Modulator is on top of the engine compartment.
How To Resolve 3 Amigos Errors On Discover II
Old 08-25-2015, 06:16 PM
R0VERGUY's Avatar
The TC light coming on is normal when a wheel slips. It's what makes our Rovers Great.
As far as the 3 Amigos coming on, I would not rush to ABS modulator so fast. Other things can trigger those lights I believe. I think a bad speed sensor can also trigger them. You should look into buying or renting an ABS amigo to read the abs fault codes. You will need one to reset the 3 amigos after you fix the problem anyway.
Old 08-25-2015, 06:24 PM
MPDano's Avatar
It lasted all the way to my work. When I went to go to lunch this afternoon, it reset itself and never came back.
Old 08-25-2015, 06:34 PM
R0VERGUY's Avatar
That sounds like you could have a speed sensor going out to me but those lights could be telling you all kinds of brake related faults.
-What kind of shape are your brakes in? When was the last time you changed the pads and rotors and changed the brake fluid?
-Do you have any brake squeal?
I've heard of just new pads, rotors, and a brake fluid flush fixing the 3 amigos so if your brakes are in bad shape then I would start there. The 2 most important systems on a vehicle are the braking and steering systems and if you even for a second think something is wrong with either of those things then I would not waste time finding and fixing the problem correctly. If an engine or transmission die while driving you can pull over, if the brakes or steering die while driving chances are you die too.
Old 08-25-2015, 09:07 PM
MPDano's Avatar
Funny you mention about the brakes. I bought the car from my mom a few months ago as she let it sit for over 7 years without running it. I replaced lot's of things to get it running and pass smog. Brakes felt low as when you push them down it did brake but if I let up and pushed again it felt like it should. No MC leaking type condition, so I flushed the whole system with new brake fluid and it felt the same. Pads are fine as I felt the material all all 4's. I never thought about the ABS back then. Now I am thinking this is the source for the brakes feeling like they do.
newfrl
Freelander
16
08-27-2020 06:55 AM
marlymarl
05-28-2011 10:34 PM
JBEGIN
08-27-2009 10:58 AM
Brad S1
10-26-2006 08:53 PM
Surfin Elvis
06-23-2005 11:08 PM
Quick Reply: TC light flashed?
