Tcu location.
Old Sep 28, 2013 | 09:52 PM
bewstpewp's Avatar
4th Gear
Default Tcu location.
Basically I sunk my disco up to above the door speakers and I managed to get it home in limp home with manually shifting it. I've already unplugged every affected sensor behind both kick panels as well as the ECM and what
I'm assuming to be a bcm under the passenger side of the dash just a precaution. In the am I plan on removing and inspection the trans range sensor as well as the Tcu. But besically I can't find the Tcu. Checked pretty much everywhere I'm accustomed to them being as well as having no luck through google and no luck. Any assistance would be greatly appreciated
Old Sep 29, 2013 | 08:44 AM
You better start with drying out your carpet and padding first.
As for any of the computers, if you feel they got wet remove open them up and dry them out.
As for the tranny computer, it is under the drivers seat.
As for the passenger seat, the only thing under there, if you have one, will be a CD player.
Old Sep 29, 2013 | 10:15 AM
bewstpewp's Avatar
4th Gear
Thank you sir. That info was greatly appreciated. The ECM didn't get submerged but the
Connectors did so they we're full of water. I have had it set up and open all night with fans pointed in it drying. But now I know where the Tcm is I can inspect that. Thank you again
Old Sep 29, 2013 | 10:33 AM
Did you pull your carpet and pad, if not, it can and will get moldy.
Make sure to clean all the connection with electric contac cleaner and the use die electric in the.
Old Sep 29, 2013 | 11:47 AM
bewstpewp's Avatar
4th Gear
I plan on using the contact cleaner as you said on it all. As for the carpet I'm going to use our interior departments shampoo machine when I return to work tomorrow
BIGTSV
Dec 20, 2013 07:23 AM
BigSkyRover
Oct 1, 2012 12:11 PM
Roveroh
Aug 7, 2008 09:42 AM
tbesselman
Jun 3, 2005 11:47 AM
cjn104
Sep 21, 2004 09:31 AM
