TD5 At problems
Old Nov 23, 2023 | 01:12 PM
JhowHenry's Avatar
Default TD5 At problems
Hello everyone, im new here, glad to meet you all
My Discovery 2 td5 got some issues which are kinda hard to solve, i already drove it to 4 mechanical and none of them were able to find out where the problem comes from and solve it. Well, the vehicle is starting normaly, but the gearbox position on dashboard is stuck on D and blinking all the time, the car is very week when driving by the streets, seems like it lacks of power and after turning on the air conditioning it get worse, that the vehicle cannot even move from inertia,
1 - My mechanical tried to search for some errors with an scanner, but there is no errors according to his scanner
Someone had this same problem already ?
Thanks
Old Nov 23, 2023 | 09:11 PM
Harvlr's Avatar
These might not be your issues, but 2 of the main issues with these transmissions are voltage out of range and improper servicing of the fluid. Make sure your voltage is good. The gearbox ECU’s are really picky about voltage. And make sure you’ve serviced the fluid correctly. Do it exactly as per the manual. The engine has to be running when you check the level.
Old Nov 24, 2023 | 07:50 AM
mollusc's Avatar
This sounds like a failing battery or a bad ground connection from the battery to the chassis/engine.
If you have not serviced the transmission recently, I would check the battery and connections first before trying to check the transmission fluid level.
Golley01
Oct 14, 2016 02:33 AM
Stephen Disco 2
Jan 22, 2016 04:10 PM
diverjohn52
Apr 3, 2011 01:27 PM
NiteTrain
Jan 1, 2011 06:41 PM
morse
Aug 7, 2006 08:41 AM
