Sponsored by: CARiD
200tdi gearbox in a td5 discovery
Old Oct 13, 2016 | 01:32 PM
Golley01's Avatar
Default 200tdi gearbox in a td5 discovery
Hi,
I have a 1994 td5 Discovery and the gearbox packed it in. I've been looking for a replacement for a reasonable price and all I can seem to find is a gearbox from a 200tdi disco and a 300tdi disco..
Will either of these fit in my TD5? Would there be any changes to the drive if I
were to install one?
Any advice would be appreciated, Thanks.
Old Oct 14, 2016 | 02:33 AM
loanrangie's Avatar
Originally Posted by Golley01
Hi,
200TDI uses the LT77 and 300TDI uses the same R380 as the TD5, i would expect the TDI R380 to be a bolt in swap for the TD5 but i cant 100% confirm that.
Ratios are the same so there will be no change at all, may as well replace the clutch and check that the dual mass flywheel is still good.
pgaukroger
Feb 29, 2016 05:56 AM
misternice
Nov 3, 2012 02:32 PM
mandythelandy
Engine & Internal
Apr 9, 2008 01:15 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
