temp hit 217F
Old Sep 24, 2012 | 01:41 PM
sorbet35's Avatar
Default temp hit 217F
MY disco hit 217F at idle today so i think its time for a new thermostat.Where is the best place to get a 180 thermostat from..............thanx
Old Sep 24, 2012 | 01:51 PM
jfall's Avatar
This is not unusual.
1) Is your radiator operating to full capacity? Is all the dirt and straw removed from the fins?
2) Fan clutch - may not be operating fully.
3) Electric AUX fan must be running at idle. It will eventually come on.
4) When A/C is on, an additional fan should fire up.
Old Sep 24, 2012 | 01:52 PM
Michael M. Koch's Avatar
Autozone. They carry a "failsafe", meaning if it gets stuck it'll get stuck open instead of closed, for around $10. They're not hard to find.
Edit: Disco I or II? Just dawned on me that the II takes a different kind of thermostat.
Old Sep 24, 2012 | 01:55 PM
Racer X's Avatar
The failsafe T-Stat that AutoZone carries doesn't apply to the Discovery II.
The 180º thermostat is a good start, but you would do well to replace your radiator. If it's never been done, then it's definitely time.
Old Sep 24, 2012 | 02:00 PM
sorbet35's Avatar
Thanks all for the reply.When im at idle the temp goes up to 217,when i rev up the rpms alittle it will go down to 208.Mabey i should just unplug the ultra gauge
Old Sep 24, 2012 | 02:01 PM
Racer X's Avatar
lol
In addition to the radiator, the water pump might be a good idea too. And not too expensive either.
Old Sep 24, 2012 | 02:04 PM
jfall's Avatar
Go up a long hill and see what it is then.
Your fan should be roaring.
This is where it matters.
At idle - you should get the AUX fan on eventually.
Old Sep 24, 2012 | 02:05 PM
oilspotLR's Avatar
Perhaps in the meantime you should unplug the A/C and then turn it on. This will bring on an additional fan while you try to solve this issue... so you can drive it without overheating!
hilltoppersx's Avatar
here you go
Motorad 439-180 Thermostat : Amazon.com : Automotive Motorad 439-180 Thermostat : Amazon.com : Automotive
Old Sep 24, 2012 | 03:20 PM
suzukisam967m's Avatar
my stat was restricted. I think it was just stuck, I could also rev the engine and drop the temp a lot. replacing my stat droped my idle temp to 194 and highway to 188.
