Temp Issues - MotoRad 180
Ever since I opened up the heater core lines the other day I can't seem to get my temps back to normal I've bled and bled and bled...
I'm hitting 201-202 at idle. Before opening the system I would see 194-197 at idle and 190.4 - 194.0 while cruising. Sometimes, I would see 188.6 on the freeway. Now, I can't get below 194.0 while crusing around town. As soon as I come to a stop temps go up to 199 201. I can't get it right.
I decided to pull the Motorad 180 stat to look for a blockage. Look what I found.
I pulled the dislodged rubber gasket out of the housing and discarded it. Is it crucial that it stay in there? Should I be worried enough to pickup another stat?
Anywho, I'm still bleeding the system temps keep creeping back up to 201 at idle The dislodged rubber gasket wasn't the problem.
cosmiccharlie
06-05-2013 10:09 PM
mx468
04-29-2013 08:08 PM
