Temp Issues - MotoRad 180
Old Sep 8, 2013 | 01:24 PM
coors's Avatar
Default Temp Issues - MotoRad 180
Ever since I opened up the heater core lines the other day I can't seem to get my temps back to normal I've bled and bled and bled...
I'm hitting 201-202 at idle. Before opening the system I would see 194-197 at idle and 190.4 - 194.0 while cruising. Sometimes, I would see 188.6 on the freeway. Now, I can't get below 194.0 while crusing around town. As soon as I come to a stop temps go up to 199 201. I can't get it right.
I decided to pull the Motorad 180 stat to look for a blockage. Look what I found.
I pulled the dislodged rubber gasket out of the housing and discarded it. Is it crucial that it stay in there? Should I be worried enough to pickup another stat?
Anywho, I'm still bleeding the system temps keep creeping back up to 201 at idle The dislodged rubber gasket wasn't the problem.
Old Sep 8, 2013 | 02:05 PM
dusty1's Avatar
Yikes, coming apart. did you flush the system at the same time, also?
Old Sep 8, 2013 | 02:18 PM
Return it for another one.
Old Sep 8, 2013 | 04:19 PM
Even better, get $$ back and buy a real Rover one, about $60, and worth it. Runs cooler than a lot of motorads people have posted about. 183F at 60mph is not gonna happen with defectiove thermostats.
Old Sep 8, 2013 | 05:21 PM
coors's Avatar
Just picked up a Genuine LR 180 stat from Rover North.
Old Sep 8, 2013 | 05:24 PM
coors's Avatar
I did a full flush afterwards. Fortunately, I didn't find any other goodies floating around in the system. It's always something w/ this thing.
cosmiccharlie
Jun 5, 2013 10:09 PM
mx468
Apr 29, 2013 08:08 PM
MC04DII
Dec 5, 2012 10:14 AM
coors
Nov 2, 2012 09:51 PM
Spencerfitch
Oct 30, 2012 07:14 PM
