Temp Jumps Up after Couple Minutes of Running
Old Mar 21, 2019 | 08:38 AM
Sarasota Rover's Avatar
Default Temp Jumps Up after Couple Minutes of Running
Need some opinions fellow Rover nuts...
Looking at ANOTHER Disco (99 SD w/ 155K, 2 owner) for the youngest son to start driving. Went yesterday and did the test drive, looking / touching, etc. All in all, drove well, brakes not soft, shifted lovely, etc. SES light on (OBD tool indicated O2 sensor). Ignition cylinder needs to be replaced, I would replace that with the kit from AB (no alarm, keyed only). Couple other minor cosmetic items needed such as couple of pillar covers, rear light mounted, etc.
Here is my 'concern' - Started up and let idle for about 5 minutes while I talk to owner, etc. Jumped in to test drive and noticed the temp had climbed to about 3/4 of the gauge and went up a hair from that point, never to the red. Temp gauge came down from that mark to just below the 3/4 mark. I'm initially thinking potential water pump not circulating, dead t-stat. Could be a clogged up radiator. Did not notice any leakage or waterfall noises, no overflow from expansion tank, etc. No antifreeze smell under the hood or a the exhaust pipe..
I know from the previous (3) I have had, chasing the overheating causes can be 'fun' to say the least.
Anybody have any thoughts?
Old Mar 21, 2019 | 09:08 AM
robert.juric's Avatar
I know I don't trust the Rover temp gauge. Could also be the fan clutch. Did the temp come down during the test drive?
Old Mar 21, 2019 | 10:05 AM
Came down a little as I drove.
Old Mar 21, 2019 | 10:28 AM
Richard Gallant's Avatar
I would be concerned that is very high, even when I had a blockage in my lower rad hose ( 2 inch long piece of wire loom protector) I never cracked the mid point and I was around 215 -218 Deg.
It could be a rad, thermostat, or just a lot of air in the system, but are you willing to roll the dice on it being a head gasket that is a considerable expense.
I would tend to pass, on this unless the price is outstanding
Old Mar 21, 2019 | 10:55 AM
Your right, certainly is a risk. I could get it at $1500 but have to decide if that's a risk I want to take...Could be something as simple as fan clutch or t-stat but....
Old Mar 21, 2019 | 11:15 AM
I wish I could provide you a simple check, but if the oil looks good and the truck runs good no misfires i guess it is just a roll of the dice. A failing water pump could cause the same issue, just not enough water flow.
Old Mar 21, 2019 | 11:35 AM
I appreciate the input. Going back over today / tomorrow to run it some more - squeeze hoses, check the dipstick again (clean yesterday), etc. No misfires recorded on the OBD and idle right at 750 +/- mark..
Old Mar 21, 2019 | 12:37 PM
jastutte's Avatar
check the inside of the oil cap for dirty mayonnaise.
Old Mar 21, 2019 | 12:58 PM
Dave03S's Avatar
Inside the oil cap can collect condensation leading to milky conditions from primarily being driven on short drives. Not an accurate indication of any problems.
Old Mar 21, 2019 | 04:41 PM
Best4x4's Avatar
I agree oil cap is not a good indication of any HG issues. 100% normal with short trips or quick on/off cycles.
