Temp levels normal ?
Old Dec 28, 2018 | 01:20 PM
escott16's Avatar
Default Temp levels normal ?
212 alittle High this is the highest it’s gone , sitting in traffic
Old Dec 28, 2018 | 01:31 PM
Ben Matheson's Avatar
What was the outside temp at the time?
Old Dec 28, 2018 | 01:50 PM
escott16's Avatar
60 f Pittsburgh pa
Old Dec 28, 2018 | 02:21 PM
Richard Gallant's Avatar
Depending on thermostat yes, if you running a 190 then yes. I run a 180 and I get up to 201- 202 sitting for a long time, but 194-197 is more normal at shorter lights.
Old Dec 28, 2018 | 02:58 PM
Best4x4's Avatar
The longer you sit the more it will climb. I saw 209F off roading last summer & I reached 215F at one time driving back from the lake pretty loaded. As long as the temp goes back down once you move = consider it normal as the temps are going to rise/fall. It’s when you reach say 215F, then it jumps to 220F = you have a problem!
Old Dec 28, 2018 | 03:08 PM
escott16's Avatar
Yeah it hit 215 but if I give it throttle it cools down , what should I set my ultraguage alarm to? 217?
Old Dec 28, 2018 | 05:13 PM
Best4x4's Avatar
I’d do 215F then you have time to watch it jump or level out. Also is your Efan on at 209F? Make sure it’s working.
Old Dec 28, 2018 | 05:18 PM
mln01's Avatar
IIRC the aux fan doesn't kick in until either 212°F or 215°F so even 220°F is probably okay for the UltraGauge alarm.
Old Dec 28, 2018 | 05:36 PM
escott16's Avatar
It just hit 221 after sitting so I might have to put a 180 thermostat in, I believe it has the 190 now
escott16's Avatar
It hits 221 but after a few seconds goes back down to around 210-215
GCBurke
Mar 21, 2019 04:54 AM
Ben Matheson
Feb 8, 2019 02:50 PM
Ben Matheson
Dec 27, 2018 01:57 PM
Ben Matheson
Nov 28, 2018 02:52 PM
zeroone
Feb 22, 2014 10:42 PM
