temp question
I also noticed that my viscous fan is always spinning. When cold the first attempt to spin it by hand it fails as expected but by the third attempt it is spinning all the way round and more. When I started the truck to warm it up after putting the cooling system back together I noticed that it ran from startup and never stopped. I hate to think that the only reason I didn't overheat was that my fan was stuck. I'll have to add it to the list of things to do.
Check your fan once its warm. Turn the engine off, and mark it to see if you can spin it.
Also, at start up you should hear a "roar" sound from the viscous fan. Take a cheap plastic bag and put it in front of the grill. See if the bag is sucked towards the radiator. This will ensure your fan blades are in the correct orientation.
twilightcall
Mar 4, 2018 06:55 PM
rrbc
Nov 13, 2009 04:59 PM
