Temperature fluctuations when driving around town
Old Feb 16, 2015 | 02:21 PM
MyRoversNameIsCarl's Avatar
Default Temperature fluctuations when driving around town
Recently I have replaced a bunch of parts in my 02 Disco 2 (~95K miles), including water pump, radiator, Genuine grey 180 t stat, and coolant hoses. Re-tightened all hose clamps (worm gear on the big ones) and so far cannot see any leaks. When I was driving around town today (ambient temp approximately 10 degrees Fahrenheit) my temps would fluctuate between 194 and as high as 203. However I have seen that people with a similar setup will have temps sometimes lower than 190. I figure that this may become a bit of an issue when the ambient temps get warmer in Spring and Summer.
I have bled the system god knows how many times and I have no waterfall noise. I played with the viscous fan today immediately after turning off the car and after giving it a hard push, it turned maybe 1/5 to 1/4 of the way around. I pressure tested and did the exhaust gas test last August and did not detect anything.
Any ideas if this is normal, or what I should be looking for? Thanks...
Old Feb 16, 2015 | 03:55 PM
OffroadFrance's Avatar
Q: what was the temperatures before you stuck all the new components into the cooling system?
Old Feb 16, 2015 | 04:10 PM
194 or less on the highway at 65mph+. In the city it would go upwards of 209 before I started to move, with the heater on in probably 40 degree weather.
Quick question: do you do the combustion gas test with the engine running or off?
Old Feb 16, 2015 | 04:46 PM
lordmorpheus's Avatar
The combustion leak test with the blue fluid is done with the engine running to see if the fluid changes colours.
jfall
Nov 23, 2013 10:58 PM
ggs
Feb 7, 2013 11:25 PM
Viajames
Jul 21, 2012 10:02 PM
ALEXAN
ROAMING WITH FRIENDS
Aug 28, 2009 09:47 PM
AUSlro
Jun 16, 2008 04:10 AM
