Temperature question
Old Nov 16, 2015 | 08:20 AM
mose802's Avatar
Default Temperature question
Just noticed that since the temperature has dropped in my area and I'm using heat my ultra gauge shows my rover is running warmer. Normally I run 200 to idle at 204. Now I'm running 204-208. Anyone else see a temperature change this time of year?
Old Nov 16, 2015 | 02:55 PM
georgep's Avatar
Yes but the OTHE WAY. 2003 is normal at 194 now 185. 2000 normal is 204-210 now 194 or lower. I verified a Radiator is in my future with the fact that I got a temp DROP so the radiator is not doing its job 100% (220,000 miles on the 2000)
Old Nov 16, 2015 | 07:12 PM
Discoaddictnorth's Avatar
You need to do the 180 degree stat . Will make a huge improvement and will stop cooking your engine
Mine went from 210 - 215 to 180-190 changing the stat.
If you temp is going up in colder temps you may have other problems
kingster
Apr 11, 2007 06:27 PM
unco
Feb 1, 2007 11:19 AM
minsane
Jan 30, 2007 08:56 AM
somekid
Jan 5, 2007 07:50 PM
lrd99
Aug 27, 2006 10:02 PM
