tensioner
Old Nov 7, 2016 | 05:58 PM
Tomzsix's Avatar
Default tensioner
What, if any, are the tell tale signs of a worn belt tensioner? Do they blow up, or just fade away? Do they make grinding noises? I have not a clue. Please let me know before anything happens and leaves me stranded.
Old Nov 8, 2016 | 06:13 AM
zuke's Avatar
They cost $17 at autozone. Swap it out and sleep better
Old Nov 8, 2016 | 08:15 AM
d.a.r.y.l's Avatar
What Zuke said. If it locks up it could severely damage the front cover and that ain't a good thing. I had that happen once so I know from what I speak. D*
Red5's Avatar
They get noisy.
If it is only the pulley, as zuke said, replace it. Last year my original unit started making just a bit of noise on Friday and completely let go on Sat morning as I was driving to Oreilly.
If the belt is squealing, then you probably need the whole assembly for about $80
Old Nov 8, 2016 | 08:34 AM
zuke's Avatar
Actually if it was me I would also swap out the bearings on the 2 idlers while I was at it. They seem to have a similar lifespan.
I think you need (1) 6203 R2S and (1) 6204 R2S as memory serves. But I could be wrong.
Probably $15 total at autozone for the 2 bearings.
Old Nov 8, 2016 | 08:45 AM
Red5's Avatar
The larger one is 6304.
Old Nov 8, 2016 | 08:49 AM
zuke's Avatar
You are right. I looked it up
small idler: #6203 r2s
Large idler: #6304 r2s
Old Nov 8, 2016 | 09:25 AM
coors's Avatar
Take the advice above and simply replace it. I had a terrifying experience driving down the freeway. Idler locked up with no warning and threw the serp belt at 70mph. Coincidentally, this stretch of freeway had no safe pull-over zones. I had to limp ~ five miles as I frantically watching my engine temp climb...
Called an Uber, went to autoZone picked up an idler and returned to the side of freeway, climbed in the engine bay, replaced it in the dark with traffic screaming past. I had better moments.
Old Nov 8, 2016 | 05:12 PM
Tomzsix's Avatar
Whats the price i'm looking at from Atlantic ?? Does fan need to come off??
Old Nov 8, 2016 | 05:34 PM
OverRover's Avatar
Go nutz! > Land Rover Belt Tensioner Kit: Discovery 2 And Range Rover P38
Yes, fan needs to come off. Looks like this > How To Replace Serpentine Belt On Discovery 2
