tensioner
Old Nov 8, 2016 | 06:06 PM
zuke's Avatar
I did this job two weeks ago. I did not take off the fan. Don't waste time ordering from Atlantic. Go to any parts house and just give them the number for the bearings. Buy the tensioner pulley and bearing together. This job is no big deal. Getting snap rings out to swap bearings was the hardest part but a small flat blade screwdriver does the trick.
Old Nov 9, 2016 | 09:53 PM
JUKE179r's Avatar
That price for tensioner kit is crazy asf...
Yes, fan needs to come off. Looks like this > How To Replace Serpentine Belt On Discovery 2
Nope. No need to remove the fan. Just remove the fan shroud/guard, have a long breaker bar and a 13mm socket to pry up on the tensioner bolt to loosen the serpentine belt for pulley maintenance.
Old Nov 10, 2016 | 09:14 AM
number9's Avatar
As others have suggested you don't need to remove fan but it does make job easier because you will have better access. If you have the right tools and have removed the fan before it only takes a couple of minutes off/on. Work smarter not harder.
ajh
Dec 19, 2007 11:30 AM
DeepBlueWater
Nov 11, 2007 01:21 PM
SnakeLogic
Dec 2, 2006 05:14 AM
evoasis
Nov 4, 2006 07:58 PM
esaycho
Oct 12, 2005 03:24 PM
