Tensioner Pulley
It's pretty much just put wrench on pulley bolt, pry tensioner up, remove belt from alternator pulley to allow slack in belt, remove tensioner pulley from tensioner, replace pulley, reinstall belt in reverse order.
Why just the pulley, instead of the whole tensioner? At that mileage, I would replace the whole thing (same instructions as above except unbolt tensioner from engine instead of removing pulley from tensioner).
Thanks Discobob,
I found the full kit here at Atlanta British.
http://www.roverparts.com/Parts/ERR6439K.cfm
I did also found the pulley at Orielly that you mensioned for $19.99. It only listed 2000-2002. So I dont know about 03/04 years(mine is a 2003). It would'nt be the first time my year was not listed in their database, but the part would fit just fine. I also found out the the two idler pulleys...one is 70mm and one is 80mm. Probably can tell by looking for the 10mm diameter difference.
http://www.oreillyauto.com/site/c/de...d=pulley-idler
