Tensioner pulley offset?
Old May 9, 2023 | 11:07 PM
Tony Luna's Avatar
Default Tensioner pulley offset?
Is the pulley on the tensioner supposed to be offset at an angle?
Old May 10, 2023 | 02:06 AM
Discorama's Avatar
That doesn't look normal. I installed a new tensioner recently and checked if the pulley lines up with the other pulleys and it did.
Old May 10, 2023 | 08:08 AM
redrover75's Avatar
Looks bad.
Does it spin on one axis?
Old May 10, 2023 | 08:56 AM
Best4x4's Avatar
Make sure where it mounts on the accessory bracket it's not cracked and blown out. Seen plenty of them let go from the aluminum cracking. Or it's just a bent bolt where the pulley attaches to the tensioner.
Old May 10, 2023 | 10:11 AM
greggnvt's Avatar
I had mine off last week and put it back on incorrectly. There is a "dimple" in the mounting bracket that the tensioner goes into. Move the tensioner up/down and allow it to fall into place.
Old May 10, 2023 | 11:40 AM
Tony Luna's Avatar
The locator tab on the tensioner is definitely in the hole.
QuakerJ
Mar 24, 2014 02:46 PM
jbkroh
Oct 19, 2012 09:40 AM
discobob
Jan 4, 2012 09:25 PM
73S3IP
Aug 10, 2009 08:46 AM
