Terra Firma +2 install
Old Aug 26, 2010 | 09:36 PM
bikingteacher's Avatar
Default Terra Firma +2 install
So halfway through doing the install and stopping for beer. The rear is on and I must have been sagging a ton, because it looks jacked up to me! I am worried that it might over extend the brake lines at full flex. Justin at Lucky 8 said it wouldn't. We'll see.
Old Aug 26, 2010 | 11:32 PM
NiteTrain's Avatar
post up some pics when you're finished
Old Aug 27, 2010 | 07:35 AM
dcarr1971's Avatar
Definitely would love to see some pictures...this is something I'm thinking about doing before or maybe at MAR, but I have lots of other stuff to address on my stock DII first.
Are you doing both the springs and shocks? All Terra Firma or different make of shock? (Sorry for the n00b question, but would it even be an option to just do springs and retain oem shocks temporarily?)
Old Aug 27, 2010 | 11:49 AM
I got the full kit from Lucky 8. About 5 hours to install by myself. Pretty straight forward. I think the back may be a bit higher than the front though.
Old Aug 27, 2010 | 12:00 PM
If you have a near 3" lift and you are at 100,000 miles or more, replace the rubber brake lines cause they are most likely aging from heat, make sure to do a full 2 quart brake flush afterwards to give you a firmer brake pedal.
Old Aug 27, 2010 | 12:02 PM
lipadj46's Avatar
That is normal, I guess the idea is that you are going to put a bunch of crap in the back so they have to account for that. Any lift is going to really high when compare to saggy beat springs. The springs will settle over time.
Old Aug 27, 2010 | 05:50 PM
http://www.facebook.com/home.php#!/p...6&id=699257945
I put a pic on Lucky 8's FB page.
Old Aug 27, 2010 | 05:52 PM
They don't look too bad. I have just over 80k on it now. The Lift is supposed to be 2 inches over stock, however, the TF 2 inch is bigger than the OME 2 inch.
http://www.facebook.com/home.php#!/p...d=123570148926
This is a side by side of two shocks.
Old Aug 27, 2010 | 07:46 PM
hilltoppersx's Avatar
The TF is more like 2 3/4"
Old Aug 28, 2010 | 08:36 AM
I'll be moving about 1500 lbs of cement blocks up to the cross country trail I developed today. The blocks will all be in the back of the truck. That ought to help the rear settle, and I am interested to see how it handles with the load.
jastutte
Apr 6, 2013 09:16 AM
ColoDisco
Apr 24, 2012 08:55 AM
AK_Disco_Driver
Apr 21, 2012 07:13 PM
bullcrew
Feb 24, 2012 08:27 AM
tweakrover
Feb 27, 2011 03:37 PM
