Terra Firma Light Mounting Bar
I've just purchased a Terra Firma light mounting bar from Lucky8:
( Land Rover Discovery Roof Light Bar Mount Fits Discovery 1989-2004 Brand New LED | eBay )
and it comes with no instructions, neither are there instructions on the Terra Firma site:
( GLB002 - Roof Light Bars )
Does anyone have suggestions? I'm sure I can figure it out with a little time, but I'm more looking to see if anyone else has tackled this project before and has any tips or suggestions for the install.
Thanks!
Thanks!
I installed mine this past summer ordered from the same place with no instructions or help from Lucky8. If you drill thru the rain gutter insert a nut thru the light bar where that + looking symbol is and then I used an allen head bolt tighten it down. Just make sure you get it lined up or its really tough to get the bar aligned. I don't have pics with me but I can send you some if you need.
You would be better off replacing the drip rails. You don't mention how long the cracks are but just as you make some type of repair in one spot, it will crack again somewhere else. there's no reliability and what then if it breaks on an attachment point and completely comes off the truck. I wouldn't trust the old piece to hold a light bar with any kind of integrity.
The light bar connects via the plastic (cosmetic) part of the drip rail, does it not? Can you post a few pics of your light bar and the installation points? Did you add the hood blackout for overhead light-reflective putposes?
