Terrafirma Front Dislocation cones - anyone running them?
Old Aug 28, 2017 | 07:44 PM
Jeff Blake's Avatar
Default Terrafirma Front Dislocation cones - anyone running them?
My springs keep smashing the stock rubber isolators and getting dislodged - not fully dislodged, just like a lip of the rubber gets caught under the spring causing the spring to look off-balance. Terrafirma part TF501 look to be the ticket - is anyone using these?
And if so, do you keep the rubber isolators as well? Because the isolators provide the studs to secure the shock tower. TF502 looks like the complimentary product, but its not listed as compatible with the D2?
My setup at the moment is TF HD springs, TF 3" all terrain shocks. I have the coil retaining plates.
Old Aug 29, 2017 | 10:51 PM
ZGPhoto's Avatar
Yeah I run them, definitely necessary when you have the travel
Old Aug 29, 2017 | 10:54 PM
Jeff Blake's Avatar
So you run the cones w/ the OEM rubber guys? I contacted terrafirma - they said tf501 works w/ D2, but TF502 does not. It sure as heck looks like TF502 will work, and allow me to delete those flimsy rubber cones. I've also found threads that say people w/ D1's use the rubber guys. Or maybe I should get genuine rubbers and use those w/ the cones?
Old Aug 30, 2017 | 11:29 AM
ZGPhoto's Avatar
Yeah of course TF502 works, that's crazy they told you that! I don't use the rubber, no.
Old Aug 30, 2017 | 11:35 AM
Jeff Blake's Avatar
Perfect, thanks!
Yep, two different people from Terrafirma both said no go on TF502. The replies came from Frogs Island 4x4 Parts Manager.
Old Aug 30, 2017 | 02:18 PM
ZGPhoto's Avatar
I've done it personally, direct fit
Old Aug 30, 2017 | 03:15 PM
KingKoopa's Avatar
Will the rear spring isolators fit on these metal cones? They won't fit the factory style rubber cones and It would be nice to have uniform components front and rear.
Old Aug 30, 2017 | 03:57 PM
Jeff Blake's Avatar
Hmm maybe. Have to wonder though, how much do those isolators really improve things?
Old Aug 30, 2017 | 04:05 PM
KingKoopa's Avatar
Not sure how much they reduce noise or vibration, but they are super handy for leveling a crooked ride height.
Old Aug 30, 2017 | 07:23 PM
Jeff Blake's Avatar
I'll order them and let you know if they work. It looks like it would
