Test drove a 02:You can hear water swooshing while turning or accelerating under.....
the dash on the pass side. Not sure if the heater core is shot or what but it blows hot air. If you turn and accelerate you can hear what is water swooshing around. What could this be?
Or the other possibility is that the a/c drain tubes are plugged and water is trapped and splashing around.
If it is a low coolant issue, you need to have it checked to make sure the truck doesn't have leaking head gaskets, cause the coolant level to drop.
bcolins
Dec 9, 2013 01:14 PM
Disco2001
Sep 20, 2011 11:11 AM
