Test drove a 02:You can hear water swooshing while turning or accelerating under.....
Old Jan 25, 2010 | 02:28 PM
AJPTransport's Avatar
4th Gear
Default Test drove a 02:You can hear water swooshing while turning or accelerating under.....
the dash on the pass side. Not sure if the heater core is shot or what but it blows hot air. If you turn and accelerate you can hear what is water swooshing around. What could this be?
Old Jan 25, 2010 | 02:33 PM
yloDiscoII's Avatar
Sounds like air in the coolant system. There is a write-up on bleeding the coolant in the "How To."
Old Jan 25, 2010 | 03:08 PM
hilltoppersx's Avatar
check the coolant level make sure there is coolant in the resovoir and then make sure you bleed the air out of the system.
Old Jan 26, 2010 | 10:40 AM
Or the other possibility is that the a/c drain tubes are plugged and water is trapped and splashing around.
If it is a low coolant issue, you need to have it checked to make sure the truck doesn't have leaking head gaskets, cause the coolant level to drop.
Adam78
Jun 1, 2015 09:05 AM
Disco2001
Sep 20, 2011 11:11 AM
Spencerfitch
Mar 13, 2011 11:30 AM
lisalisa
May 7, 2006 11:11 PM
