Test passed
Old Oct 12, 2012 | 11:38 AM
No body's Avatar
Default Test passed
I made the electric test on the shuttle valves switches, and I passed it with the right values ​​of resistance, as says in manual.
Please somebody help me with another way what must I do now?
Old Oct 12, 2012 | 11:43 AM
What else do you need, be more specific.
Old Oct 13, 2012 | 12:00 PM
No body's Avatar
Default I need
What should I do no, after I passed the test of Shuttle valve, what other work need to do?to eliminate the three amigos?
Old Oct 13, 2012 | 03:07 PM
Bkreutz's Avatar
Get the fault codes read. The shuttle valve wiring bypass only addresses a specific (and common) fault. You could very well have something else wrong but you won't know until you know what codes are being set. Any fault that come up in the ABS system will also disable the hill descent and traction control.
Old Oct 16, 2012 | 02:25 AM
No body's Avatar
Default The fault codes
Yes my friend i get my fault codes they are:
-Pump failure 1 (monitor line)
-Pump failure 3 (pump sticking)
-Shuttle valve switch failure
-Rear right Inlet valve short to Internal Supply
Those were the 4 codes, I think I have problem with the "Rear right Inlet valve" but I do not know if it can be replaced or not, may also I have the problem with the Shuttle valve (spin). please help me with any opinion, by the way these parts, where can I buy?
Thank you
Old Nov 22, 2012 | 04:20 AM
No body's Avatar
Default 3 Amigos without solving
My friend i get my fault codes they are:
I made the measurements of the SVS resistance and resulting in norms,
as described in the manual. Please if I act according to the version B (making the bypass) may disappear these f**** lights?
Any advice would be appreciated
Old Nov 22, 2012 | 11:56 AM
Bkreutz's Avatar
Doing option B might address the 114 fault (SVS failure) but that is questionable if the switch tests normal. The option B will probably have no effect on your other faults. (the reason I put in might and probably is that with my experience in Land Rovers I'm always getting surprised so I never use absolute terms)
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
Macbeth
15
May 8, 2013 06:07 AM
Scharfire
Jul 14, 2012 09:12 AM
MuddMouth
ROAMING WITH FRIENDS
Nov 6, 2010 08:02 PM
roverboy
Jan 15, 2009 03:22 PM
