Testing for a blown headgasket or crack in the engine?
Old Jan 22, 2013 | 12:37 AM
TRIARII's Avatar
Default Testing for a blown headgasket or crack in the engine?
UVIEW 560000 Combustion Leak Tester: Garden Center : Walmart.com
Has anyone ever used one of these on their Disco? Are they safe to use on our trucks and are they accurate or recommend? I do not "NEED" to test it yet but I'm curious and the kit is only $61 and beats driving to a mechanic shop to have them test it. What do you guys think? I may purchase the kit next month once my shafts and O2 sensors are serviced and out of the way.
Old Jan 22, 2013 | 12:43 AM
DiscoRover007's Avatar
Are you leaking coolant? Why bother if you don't have to? If you need the peace of mind I guess I understand but if she's running good she's running good.
Old Jan 22, 2013 | 01:00 AM
These testers do about 15 tests with fluid provided, and you can buy more fluid. Some parts stores rent/loan out the thing. Some fools that go to auto auctions use them to pre-bid inspect any English vehicle, and some others. Changes color.
Attached Thumbnails Testing for a blown headgasket or crack in the engine?-block_test_fluid.jpg
Old Jan 22, 2013 | 07:10 PM
Bkreutz's Avatar
Save your money, something else will fail shortly (unwritten LR law)
Old Jan 22, 2013 | 07:26 PM
JoeLena's Avatar
...Some fools that go to auto auctions use them to pre-bid inspect any English vehicle....
Is that a bad idea? Seems like might be a wise investment when shopping for a LR, but as noted, if it is not the HG it will be something else.
Old Jan 22, 2013 | 08:22 PM
It is also a good "proof of performance " test for head gasket jobs.
Old Jan 23, 2013 | 06:10 AM
mln01's Avatar
Buzz, which auto parts chains have you seen rent/loan this tester? In another thread I've written that a friend may have a leaking headgasket or a cracked block.
Old Jan 23, 2013 | 08:07 AM
Some one else posted about a loaner, I guess that varies by area.
SedonaDiscodick
Jan 2, 2015 11:25 AM
widowmaker223
May 4, 2013 09:54 AM
clandrovers
64
Feb 19, 2013 12:05 PM
viperdisorder
Mar 6, 2011 08:22 PM
jkeving
Mar 8, 2007 03:28 PM
