Is there a way to connect an external toggle switch to control door locks on a D2.
Old Aug 7, 2016 | 12:21 PM
discorey's Avatar
Default Is there a way to connect an external toggle switch to control door locks on a D2.
I want to hide a toggle switch on the exterior of my D2 that will somehow be connected to my interior door lock toggle switch or the toggle inside the drivers door.
Has anyone tried anything like this? Any suggestions on type of toggle switch and wiring?
I want to do this because the pin in my drivers door lock has been broken and I'm tired of searching for a new one. My drill isn't good enough to make one out of steel, not potmetal. And a nice replacement is $85. I'm thinking I can make an external toggle switch for about $10 for the switch and wiring.
Any suggestions are appreciated. Thanks.
Old Aug 7, 2016 | 12:39 PM
number9's Avatar
Once you get your parts and figure how to wire the circuit, please get back with a description and wiring diagram. Many of us would be interested. Thanks.
Old Aug 7, 2016 | 03:27 PM
coors's Avatar
Thinking out loud....You might be able to by-pass the bcu to unlock the doors but immobilization will still exist, No?
Old Aug 7, 2016 | 03:36 PM
discorey's Avatar
I'm unsure if that would work because the actual driver's door lock is more analog than mechanical. If I bypass the bcu, I would still need a way to unlock.
Going to try wiring up something. I feel like a 3 position switch can potentially work.
Old Aug 7, 2016 | 03:39 PM
discorey's Avatar
Yes, once I figure out what works, I'd like to do a write up for the folks who have a broken door lock pin and/or no longer have a door remote.
Old Aug 7, 2016 | 07:53 PM
coors's Avatar
It takes minutes to replace a door pin...
Old Aug 8, 2016 | 08:20 AM
jamestfl's Avatar
Yeah, and look for the replacement pin that's $15 bucks. Redid mine a few months ago. It's either miami British or some place in Miami. And the replacement is fairly easy.
Shiftonthefly1
Jun 4, 2017 09:34 PM
MuleyJ
Aug 22, 2012 04:57 PM
bradical
Jul 31, 2012 06:00 PM
KyShark
May 23, 2011 09:59 AM
AZRover
Feb 11, 2010 04:15 PM
