(Thermo Help) Overheating... STILL
#21
It's only gotten warm three times, and only (barely) in the red just for a second, the third time. I'd never let it get too warm (I hope).
The times that it happened though, it didn't make a difference whether it was cruising with airflow or not.
It's the thermostat NOT OPENING for some reason.
#24
Hello, Elboy!
Nope, not yet. I had a full day, and I had to end up using my wife's Rover.... ;(
Just getting home- I tried to track down a new thermostat while I was out and about, but no luck. I'm hoping I some how got a bad one.
I'm printing off the belt diagram, and am about to head out to check it.
Talk to you soon!
Pat
PS- THANKS for posting this.
Talk to you soon!
Pat
#26
Hey D2F,
since you have 2 thermostats why not try removing the innards of one so it can't be blocked. Then fit it and see how it goes. This will either confirm or deny the thermostat being the issue.
On the routing - you should download the RAVE manual. it will show you what all those parts are.
Good Luck!
________
EASY VAPE VAPORIZER REVIEWS
Good Luck!
________
#27
#28
#29
I've got the RAVE manual on my external at my office.
My vehicle HAD ACE at one point- I wonder if the previous owner removed it?
Hey guys- tonight, I start it and the thermostat opened... I haven't taken it for a drive yet...
Blowing warm air, idles fine at normal temp, all hoses warm and pressurized.
Hey guys- if I dropped a sleeve, it would run rough or something, right?
#30
If you dropped a sleeve Pat you would know it, she would be knocking and or running rough.
As for the ACE, not all trucks came with it, it would be big $$$ to remove it because there are hydrulic rams by the shocks to control body roll.
And to remove everything and reprogram the computer and...alot of work and money for nothing.
It would be pretty easy to install the t-stat backwards and not know it.
