Thermostat Replacement
Old Jul 11, 2008 | 08:41 AM
dms98e's Avatar
Default Thermostat Replacement
I need to replace the thermostate but I'm not sure if I need to get a high or low temp one. They range from 160-195 degrees. Which should I get?
Old Jul 11, 2008 | 08:46 AM
Default RE: Thermostat Replacement
Can't tell you for sure but would suggest you order one from Atlantic British or Rover Connection, they will know for sure.
Old Jul 11, 2008 | 09:01 AM
Switzer's Avatar
Buy the OEM replacement. Atlantic British sells one for around $20.00. If you buy a low temp thermostat the engine may never warm up enough affecting fuel and heater efficiency.
Cheers,
Pete
Old Jul 11, 2008 | 11:32 AM
herblatham's Avatar
my replacement was 195, 8 bucks from oreilly's, not one problem, about a month ago
Old Jul 11, 2008 | 03:38 PM
Go to atlanticbritish.com and you can get a t-stat and gasket. You might beable to get it from the dealer for less than buying and shipping from AB.
Old Jul 11, 2008 | 03:39 PM
Remove the upper radiator hose, unbolt the goose neck, remove t-stat. Make sure that you put the new one in the same direction as the old one. It will overheat if you put it in backwards.
Old Jul 11, 2008 | 03:40 PM
llesra's Avatar
i put a mr. gasket 180 degree high flow thermostat earlier this year for $12. the heater was still good and the temperature gauge read very slightly lower. part number 4364
Old Jul 11, 2008 | 03:42 PM
Never use a low temp t-stat, unless you live in the Sahara.
slskier88
Jan 15, 2014 09:41 AM
tgarnick
Jan 8, 2013 12:13 AM
younk's rover
Engine & Internal
Nov 16, 2010 01:05 PM
thelokolobo
Feb 20, 2008 08:19 AM
mcanavan
Dec 9, 2004 05:42 PM
