Which of these two options?
Old Jun 1, 2025 | 03:41 PM
Brandon318's Avatar
Default Which of these two options?
I'm needing my instrument cluster to inherit the mileage of a BCU. NOT have the BCU inherit the mileage shown on the instrument cluster. Nanocom instructions are super vague and I only have one shot to get it right.
Context: @Extinct graciously let me borrow a ECU/BCU to troubleshoot a no-start issue and when I installed the loaner BCU, I'm 99% certain I told Nanocom to Sync BCU to Odometer, hoping it would preserve my IC milage (212K) but instead it brought over the BCU mileage (80K). My old BCU has the old mileage stored on it, and I'm afraid if I select the wrong one, I'll sync the 80K to the BCU and forever lose my original mileage on the odometer.
Old Jun 1, 2025 | 09:05 PM
Harvlr's Avatar
Interesting. I thought it always would register the highest odometer reading.
Old Jun 1, 2025 | 09:39 PM
Best4x4's Avatar
It will only sync to the higher mileage. If your cluster is 200k and your bcu is 100k it will change the bcu to 200k. If your bcu was 200k and the cluster was 100k it would make the cluster 200k. I've done many times and it will indeed keep the higher mileage. Or you can slap in a 100k cluster on a 200k bcu and simply just disable Odometer flash option and it will simply display the cluster 100k. My Nanocom has 1.36 firmware.
Disabling Odometer flash is usually the first option vs performing the sync.
Old Jun 1, 2025 | 10:35 PM
Brandon318's Avatar
Where is the option to disable the odometer flash? For some reason I can’t find it.
Old Jun 1, 2025 | 10:38 PM
Brandon318's Avatar
Me too. It displayed 80k, then I disconnected the battery, reconnected, and the odometer reverted back to the 200k mileage. Not sure what’s up with that momentary 80k display, but all seems to be resolved now at the proper mileage.
Old Jun 3, 2025 | 09:03 AM
Best4x4's Avatar
Under BCU setting/trans-lock-warn
Greendisco12
Range Rover P38 (2nd Gen)
Jul 6, 2021 08:08 AM
Sean Winter
Feb 17, 2021 12:41 PM
Red320
Apr 29, 2018 09:07 AM
Tarheel Rover
Sep 10, 2013 06:36 AM
