Thought I was done.
Old Apr 2, 2010 | 02:53 PM
ChanchoVerde's Avatar
Default Thought I was done.
Just finished replacing valley pan and IM gaskets. Changed the plugs, wires, thermostat and updated top hose with bleed screw. Just turned the key and the beast fired up and sounds great.
Problem is that after bleeding the coolant system, I only get cold air in the cabin. All is quite behind the glove box and the temp gauge reads normal.
Any ideas?
Old Apr 2, 2010 | 03:10 PM
lipadj46's Avatar
Did you raise up the expansion tank onto the battery compartment while you were filling?
Old Apr 2, 2010 | 03:15 PM
Nope.
Old Apr 2, 2010 | 04:22 PM
You still have air in the system. Wait till the engine is cold, then bleed it, do it a couple of times if need be.
Old Apr 2, 2010 | 04:35 PM
lipadj46's Avatar
So this time unclip the expansion tank and raise it up on the battery box. It needs to be the highest point. So lift it up and pour more AF in then undo the bleed valve and let any bubbles escape.
Old Apr 2, 2010 | 06:04 PM
That did the trick. Hot air blowing out now.
Thank You!!
Old Apr 2, 2010 | 06:20 PM
lipadj46's Avatar
Congrats, good work
Old Apr 2, 2010 | 07:27 PM
Thanks lip. You were a big help.
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
kfx4001442
May 18, 2008 09:50 PM
Darover
Dec 8, 2007 12:15 PM
antichrist
Sep 16, 2007 06:28 PM
