threaded insert removal
Old Sep 29, 2007 | 12:35 PM
cbrantner's Avatar
Default threaded insert removal
I just removed my ladder because it was badly rusted. I had to cut one of the screws to get it off, and I can not get the insert out, or the remaining screw out of the insert. I drilled the screw and tried to use a screw remover, which I have used successfully before, but it will not loosen.
Any suggestions?
Old Sep 29, 2007 | 07:37 PM
Landzu's Avatar
Default RE: threaded insert removal
If you can kill the rust I would then grind it down and then
get some body filler paint it and be done.
If this is under the tag take to a body shop, everyone
knows someonethat does paint and body work, don't they.
Should not run more that $100.
aguison
Sep 17, 2012 03:07 AM
0304Disco
Apr 11, 2011 03:47 PM
disc oh no
Dec 25, 2010 04:14 PM
ljdiscovery
Jul 20, 2008 03:24 PM
sna77
Feb 21, 2007 06:44 PM
