Three Amigos...
Old Oct 24, 2011 | 05:26 AM
drowssap's Avatar
if you are replacing your pads I would suggest Akebono pads, i'm told they have great life and absolutely no brake dust. Brake dust can also cause Amigo problems so it's worth the extra cash to eliminate a future problem.
Old Oct 24, 2011 | 06:33 PM
Kalel's Avatar
Will I need any special tools for this?
Old Oct 24, 2011 | 07:48 PM
DonRW2007's Avatar
Default Falconworks kit
I posted about a three amigos issue a couple weeks ago (Mike - still owe you a call before I tackle this - thanks for the help). My question is, if using the Falconworks replacement kit, is it necessary to also do the recommended fix/mod discussed in the stickies?
Old Oct 24, 2011 | 08:18 PM
ATLDisco's Avatar
When mine came on @ 130K, I bought the Atlantic British kit and replaced the shuttle valves.
Kit was $65 + shipping (multiple item order - go figure with a rover...) and took about 45 minutes to do the swap. I did it WITHOUT removing the modulator, which is OK if you have skinny fingers and some patience. I used the jycsalas link on his website.
No amigos. at. all.
It was, in essence, a $65 gamble, but let's be honest, I've gambled far more on far dumber (and blonder) things in the past. If you're gonna dive in there, I'd just swap it and be done with the deed.
IMHO, they're gonna fail sooner or later, and I like to do the easiest/cheapest things first. So I started with a job that can be done at waist level, with minimal tools, and a place to put my beer.....
Old Oct 29, 2011 | 03:52 PM
Kalel's Avatar
So Falconworks or AB? I need to do this soon, as I am tackling the CDL install soon.
Old Oct 29, 2011 | 05:22 PM
Falcon Works, cause you need their newly designed o-rings which is what leaks in the first place killing the shuttle valves, with out the new o-rings it will still leak and come back.
Old Oct 29, 2011 | 08:22 PM
Kalel's Avatar
Thanks Mike, I will be ordering them asap.
Old Nov 3, 2011 | 09:55 PM
Kalel's Avatar
Kit just arrived today. It calls for a specific brand of fluid. Do I need to use this? I do not mind using it, but I still have some fluid left over from my brake flush.
Old Nov 4, 2011 | 06:00 AM
drowssap's Avatar
What type of fluid is it calling for? should be dot 4
Old Nov 4, 2011 | 07:16 AM
drowssap's Avatar
sorry; you said brand not type.
my mistake.
