Three Amigos
Another common problem is that the hub wears out, and then triggers abs codes... in that case you have to replace it. With whatever you want. New from the dealer is probably over $500. Aftermarket is probably more like $300. Some have even put used ones for less than $100.
064:Front Right Sensor Electric Fail
084 I couldn't find.
Based on the electric fail, i'd probably just replace the sensor first.. or at least check to see how the connector looks in the wheel well, if there is one still.
