Three Amigos
Old Sep 26, 2012 | 03:56 PM
Timothy Wright's Avatar
Default Three Amigos
2003 Disco II
Replaced the ABS modulator.
front right hub is what my local shop tells me is causing the code.
Any way to fix the hub? Or do I need to replace it?
Any need for OEM?
Thanks!
Tim
Old Sep 26, 2012 | 04:16 PM
jafir's Avatar
Originally Posted by Timothy Wright
2003 Disco II
Any need for OEM?
Depends why they are saying it need to be replaced. The service manual says that the sensors are not replaceable, and that you have to replace the hub. The sensors are available. So if that's what wrong, you can fix it.
Another common problem is that the hub wears out, and then triggers abs codes... in that case you have to replace it. With whatever you want. New from the dealer is probably over $500. Aftermarket is probably more like $300. Some have even put used ones for less than $100.
Old Sep 26, 2012 | 06:12 PM
If he is saying that the actual hub is bad, there is no repairing it.
Find out exactly what he feels is bad and how he tested for it, hope he isn't guessing.
Old Sep 27, 2012 | 09:23 AM
I had my local LR shop pull these codes for me, against their will!
4044
4064
4084
Old Sep 27, 2012 | 09:34 AM
ZGPhoto's Avatar
Rovers North - The Source for Classic Land Rover Parts - HUB ASSEMBLY FRONT DISCOVERY II
Old Sep 27, 2012 | 10:10 AM
jafir's Avatar
4044
4064
4084
044:Front Right Sensor Output Low
064:Front Right Sensor Electric Fail
084 I couldn't find.
Based on the electric fail, i'd probably just replace the sensor first.. or at least check to see how the connector looks in the wheel well, if there is one still.
majrmike
Jun 6, 2016 03:05 PM
ROVER2K
Sep 18, 2007 08:02 PM
igriego
Aug 24, 2007 07:09 PM
offroader
Jun 16, 2007 12:31 AM
skrams
Feb 7, 2007 11:50 PM
