Three Amigos
Old Jan 11, 2019 | 03:34 PM
longshot's Avatar
Angry Three Amigos
I did the "option B" three amigos fix and it didn't work. I double checked my work, checked my ground, the lights are still on. Any ideas?
Old Jan 11, 2019 | 03:44 PM
CollieRover's Avatar
Did you clear them after the fix? They will not reset themselves
Old Jan 11, 2019 | 04:35 PM
longtallsally's Avatar
And did you confirm with a proper code reader that the shuttle valve was in fact the issue? Option b is “a” fix, not THE fix.
Old Jan 17, 2019 | 01:58 PM
longshot's Avatar
No, but I will, thanks.
Old Jan 17, 2019 | 06:23 PM
Best4x4's Avatar
Yep SLABS = will permanently store codes unless you clear them with a proper scantool.
Old Jan 17, 2019 | 07:39 PM
mln01's Avatar
Option B is worth a shot if you have The Boys from South of the Border but don't have easy access to a tool to read the ABS codes since in many, many cases the shuttle valve switch circuit is the problem. Look at it this way; Option B is inexpensive, relatively easy and doesn't take much of an investment in time, and even if the SVS circuit wasn't the problem if you've done Option B correctly it will never be the problem. Kind of like preventive maintenance.
That being said, now that you've done Option B and it didn't work you will need to get the ABS codes read. There are several faults that trigger the Three Amigos and aside from Option B you're only guessing without the codes. The next most likely is a wheel speed sensor fault but without the codes you don't know which of the four.
Old Jan 18, 2019 | 02:40 PM
jastutte's Avatar
^this.
Old Jan 18, 2019 | 03:04 PM
Best4x4's Avatar
Yep I don’t consider Option B a mod, but a repair to bypass the weak internal connection inside the WABCO unit. I do it on any D2 I get my hands on, then I sort out the sensors and bingo no more 3 Amigo’s that affect so many D2’s.
04duxlr
Mar 26, 2020 07:38 PM
OffroadFrance
Jul 1, 2018 02:42 PM
ImQuattro
Jul 11, 2014 03:57 PM
GadgetRick
Feb 9, 2012 10:18 PM
joatman
Jan 11, 2011 08:39 AM
