Three amigo's anyone?
Old May 6, 2010 | 02:21 PM
RoverRookie's Avatar
Default Three amigo's anyone?
Well I had the darn things scanned and the mechanic told me my modulator circuit board was faulty. They cleared the left rear sensor and no more amigo's! Should/could I repair the modulator or if I have to replace it any advice? Thanks a ton - RR.
Old May 6, 2010 | 03:16 PM
hilltoppersx's Avatar
yeah see www.landroverclubvi.com/
it has Josh's write up on the modulator fix.
what were the exact codes that were being pulled off the ABS system? you need to make sure that is what is wrong with your truck.
Old May 6, 2010 | 04:00 PM
Thanks Ed, my mechanic said it might be as simple as clearing and recalibrating the left rear sensor. He also cleared and reset the celenoid in the modulator. He said if it happens again and if it's the same read he would start with replacing the sensor and go from there. All I know is there is no more amigo's ...for now. - RR.
Old May 6, 2010 | 04:58 PM
devildog01's Avatar
Just a hunch but if its the left front sensor output you may need a new hub.Or you can be like me and just ignore your amigos like I do my ex wife.
Old May 6, 2010 | 08:10 PM
your mechanic doesnt know what he is talking about.
next time your abs light comes on three amigos or not get the abs codes read by your mechanic and bring us the exact codes. or by yourself an ABS amigo and pull the codes yourself. it may not be a shuttle valve problem but as devildog said the sensor itself of the hub. could also be the rotor or brake dust...
Old May 7, 2010 | 02:25 PM
Thanks again, I really appreciate it. Ed, if I were to replace my brake pads could you( or anyone ) recommend a brand? Thanks in advance to everybody! - RR.
Old May 7, 2010 | 02:31 PM
http://www.ebcbrakes.com/automotive/...ads_7000.shtml
Old May 7, 2010 | 03:24 PM
Shane83's Avatar
Good ol' forum antics!! They make me smile very single day!!
Keep up the good work...
j.dstasio
Jun 20, 2012 02:33 PM
silver06hemic
Jan 2, 2009 03:51 PM
Dino76
Feb 12, 2008 03:03 PM
ajh
Oct 12, 2007 09:02 AM
lrblack12
Aug 22, 2007 02:35 PM
