Three Amigos? Should I care?
Old 05-21-2015, 03:32 PM
dusty1's Avatar
Follow this for option b
LAND ROVER CLUB V.I. - Home
Old 05-21-2015, 03:59 PM
If you're not comfortable doing the Option B mod these kits work perfectly with a slightly different approach. Me being a lazy SOB bought one and fitted it in about an hour or so and no probs to date More expensive but they do work fine and the tech side is already sorted for you.
Landrover Discovery 2 Defender ABS Modulator Shuttle Valve Switch Repair Kit | eBay
dusty1 (05-21-2015)
Old 05-21-2015, 05:19 PM
cappedup's Avatar
Wow, not seen those. Little money spinner for someone. Buy a switch for £30. Few wires and plugs, sell for £80.
Yes, it's a bit of soldering and snipping and messing about. And that would take some of the headache away.
Although, getting the modulator raised enough, but not too much was my biggest issue. Blocks of wood, the right little socket etc.
Good luck.
Old 05-21-2015, 06:45 PM
disc oh no's Avatar
ABS is overrated.
Old 05-21-2015, 06:54 PM
abran's Avatar
The only thing that kit doesn't have is the o rings, which are the reason for the leak in the first place, which causes damage to the circuit board.
Falconwerks in AZ has then for around $30.
Old 05-21-2015, 07:20 PM
You're right Abran. Quite often the nub of the problem is the shuttle valve seals and the only place they are available, as you rightly state, is Falconworks, expensive, damned right, but they have the market cornered. I even tried Wabco directly but they wouldn't play ball because LR sell the repair kits for £450 or a whole new modulator for a kings ransom.
Old 05-21-2015, 07:26 PM
Good luck.
That's what 4x2 was made for and 4" is adequate to get a 1/4" drive ratchet with an Allen head socket in. Don't forget to release the brake pipes from the bulkhead clips first though.
Old 05-22-2015, 03:02 AM
petminded's Avatar
It usually means the brake fluid is getting past the seals, leaking onto the shuttle valve and making the switch not work.
You can take it off, have a look, see if it is greasy looking. Ie, fluid leak. If it isn't, swap it. If it is, swap it and the seals.
Search for SVS repair, option B repair. And get a large cup of coffee.
Thanks. I don't drink coffee, so do u mean this will take a while?
If its likely the SVS is bad/leaking and if I replace the SVS and the seals why would I want to modify anything... esp something that controls my breaking (I should note I have not had the time to read what options A and B involve... or why one would do such a mod)
Old 05-22-2015, 04:58 AM
disc oh no's Avatar
You don't drink coffee?!?!? It cannot be fixed.
Old 05-22-2015, 09:28 AM
cappedup's Avatar
This is the actual page, which seems to have returned. I could only ever find it through an archive. It helps when all the photos are there!
abs mod
Makes for a very good read. Great photos.
Quick Reply: Three Amigos? Should I care?
