Three amigos, yay
Old Jan 9, 2008 | 04:49 PM
mac25dm's Avatar
Default Three amigos, yay
Well I took the disco to the car wash and sprayed and washed it, did the underside too, steering, blah blah. Now I have the amigos that are on. Any ideas before I go to the stealership to have them read? I am hoping that I just knocked something loose. Been on about two days. Yay, just when I think all is right in the world, bam. Thanks, MAC
Old Jan 9, 2008 | 05:00 PM
okdiscoguy's Avatar
Default RE: Three amigos, yay
I would go to a smaller shop and have them read and cleared. Most times the dealer won't clear them unless you get something fixed. Call them and make sure they will clear them before you take it in. As Mike says, most times just set off by a glitch. Write them down, have them cleared, and if they come back the same later, you know where to start.....
Old Jan 9, 2008 | 06:25 PM
ajh's Avatar
ajh
Before you do that, open all the plugs and fill them with di-electric silicone grease to prevent them from getting wet in the future. Also inspect all your sensor cables to make sure that you don't have any cuts of nicks. I did and that ended up triggering them a few times costing a few hundred to reset alone, plus piles more.
Old Jan 9, 2008 | 08:45 PM
mac25dm's Avatar
Where are the sensors located? Just do a general inspection underneath.
Old Jan 9, 2008 | 11:10 PM
ajh's Avatar
ajh
In the hubs. The wires are thin black cables going up from there along the brake lines.
tornado_735
Nov 9, 2009 06:35 PM
discoxd
Oct 17, 2008 11:14 PM
discoxd
Oct 14, 2008 02:21 PM
okdiscoguy
Oct 15, 2007 08:56 PM
Desertdualsport
Nov 3, 2006 08:03 PM
