Throttle Body bolt hole stripped
Old Oct 10, 2018 | 09:34 AM
nmacej's Avatar
Default Throttle Body bolt hole stripped
Hello everyone. So, my TBH was leaking, and when I got the kit in and got to work I found that one of the bolt holes (holding the flange to the throttle body) is stripped out, preventing the flange from seating snugly. So here's my 2-part question... Any solid fix for this (lock-tite, epoxy, etc)? I'm not sure how hot it gets, so maybe a mechanical hold is best? If not, would grabbing a new throttle body from a u-pull yard suffice? I've never worked on a throttle body before, but my gut says they're not plug and play, and would need to be calibrated to some degree? Any thoughts? I'd rather not by-pass it, as I'm in the North East, and regularly drive through the white mountains in the colder weather.
Thanks!
Old Oct 10, 2018 | 09:36 AM
zuke's Avatar
My winters get down to -30. I think you will be fine.
Old Oct 10, 2018 | 09:47 AM
CollieRover's Avatar
It is a really small bolthole to fix, but you could measure and get a timesert or helicoil. I'd prolly do timesert, but helicoil may be fine. I resurface mine with sandpaper to get a nice flat surface this last time I did the gasket. It had rounded quite a bit.
Old Oct 10, 2018 | 10:04 AM
zuke's Avatar
Or just drill out slightly larger and re-thread with a larger bolt.
Old Oct 10, 2018 | 02:03 PM
nmacej's Avatar
Part of me wants to just toss a dab of JB Weld in there and call it a day haha. What is the bypass procedure? I can find tons of opinions on whether to do it or not, but no actual procedure/parts list. I think I'll need to by-pass for a day or two until I have time to mess with retapping/threading.
Old Oct 10, 2018 | 02:07 PM
zuke's Avatar
Just put a bolt in the feed hose hose and put a hose clamp on it.
Old Oct 10, 2018 | 02:46 PM
Best4x4's Avatar
Bypass it & forget about the leak every 4 months (if your lucky) from that poorly designed TBH Plate! You can simply plug the lines or run a hose from the intake manifold back to the reservoir, the choice is yours.
Old Oct 10, 2018 | 03:24 PM
Friday Night Disco's Avatar
I ran a hose directly from the intake manifold to the expansion tank.
Very straight forward, get about 3' of 1/4" fuel hose from your local auto parts store and two worm clamps.
Old Oct 10, 2018 | 03:27 PM
tcr6v1's Avatar
I'd say bypass. I've only had my throttle body freeze on me once when it was -30° and the truck sat for 3 weeks. And even then, it frozen just barely open, more of a inconvenience than real danger.
Old Oct 10, 2018 | 03:38 PM
nmacej's Avatar
My thought was to connect the two hoses with a brass fitting and snap clamps, then close off the TBH ports with a section of hose going from one to the other. Am I not thinking about this system correctly? Why is everyone running a hose to the expansion tank?
Nick
